[완료]쿽파일이 어떤건지 안열려요!
[완료]쿽파일이 어떤건지 안열려요!
전준구 2 3,609
파일을 받았는데요 맥에서 쿽 파일이 뜨지를 않네요.
쿽파일 있는거는 같은데 맥에서 쿽파일 열릴수 있게 도와주세요^^*
헉 파일이 안올라가네..ㅜㅜ
쿽파일 같은거만 올려볼게요!
gsfgsd
n the <h2><b><a href="http://www.cartierreplicawatch.net">cartier ladies watch</a></b></h2> world. You can find <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watches</a></b></h3> these watches in a variety of colors and <h2><b><a href="http://www.lreplical.com/categories/gucci-bags.html">Gucci Handbags</a></b></h2> styles and they look <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> good in just about every setting from <h2><b><a href="http://www.ireplical.com">designer handbags</a></b></h2> the workplace, to a <h3><b><a href="http://www.ireplical.com">designer bags</a></b></h3> formal dinner, and even when you are out <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> with friends. There is <h3><b><a href="http://www.bestswissreplicas.com/replica-swiss-watches-raymond-weil-shine.html">Raymond Weil Shine</a></b></h3> always a place for A. Lange & Sohne watches. <h2><b><a href="http://www.bestwatchesreplica.com/products/bvlgari-b-zero1-30mm-bvlg-57-223-watch-replica.html">cheap Bvlgari B.zero1 30mm BVLG-57-223 watch replica</a></b></h2> The only problem? These <h3><b><a href="http://www.bestwatchesreplica.com/products/cartier-pasha-diamond-bezel-cart-50-285-watch-replica.html">cheap Cartier Pasha Diamond Bezel CART-50-285 watch replica</a></b></h3> watches are very costly and <h2><b><a href="http://www.handbagdesigner.net/brand_dir/replica-gucci-handbags-new-arrival-designer">Gucci handbags New Arrival</a></b></h2> the average person does <h3><b><a href="http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags/replica-mulberry-handbags-mulberry-handbags-designer/replica-mulberry-handbag-8889-hs-sgp-designer.html">Mulberry Handbag 8889-HS-SGP</a></b></h3> not have the disposable incom
참고로 맥에서 sit로 압축을 해서 받으시면 이런문제가 없습니다.
특이 FAT32로 포맷된 하드를 경유하는 경우에는 반드시 압축을 해서 옮기셔야 됩니다.
