외장하드와 서체
외장하드와 서체
1234 5 4,410
안녕하세요
궁금한점이 있어서 이렇게 글을 올립니다
다름이 아니오라
외장하드이름을 바꾸는 방법과
쿼억에서 도큐멘트를 열어서 글씨박스로 글씨를 쓸때 설정되는 서체는 어디서 바꾸는건지요?
어찌보면 간단한것을 모르고있네요-_-;
replica tiffany
e of <h2><b><a href="http://www.ebestwatch.com/products/vacheron-constantin-738.html">Vacheron Constantin Classique Tourbillon V_CONST-5-994 imitation</a></b></h2> women.The Cronoscopio Mark II <h3><b><a href="http://www.ebestwatch.com/products/tag-heuer-341.html">Tag Heuer Grand Carrera Calibre 17 T_HEU-52-901 imitation</a></b></h3> watch is large at <h4><b><a href="http://www.ebestwatch.com/categories/wyler-replicas.html">exact replica Wyler</a></b></h4> 48.5mm wide and in black steel (case is 200 meters water <h2><b><a href="http://www.ereplical.com">replica handbags</a></b></h2> resistant and the crystal <h3><b><a href="http://www.ereplical.com/products/prada-nylon-canvass-tote-cream-pd2354-06-3895-bags.html">Prada Nylon canvass tote-Cream PD2354-06-3895</a></b></h3> is of course sapphire). <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> Like each of these Replica watches, Anonimo uses <h2><b><a href="http://www.exactreplicas.net">exact replicas watch</a></b></h2> a special Drass blackening <h3><b><a href="http://www.exactreplicas.net/replica-ferrari-yellow-chrono-ss-case-quartz-ss-band-replica-watch-feai-a01.html">Ferrari yellow chrono ss case quartz ss band replica</a></b></h3> process for the black <h4><b><a href="http://www.exactreplicas.net/replica-bell-and-ross-mechanical-replica-watch-bell-825.html">Bell and Ross Mechanical</a></b></h4> toned steel. Note the non black pushers and large <h2><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-constellation-replica-swiss-watches-4680.html">Omega Constellation Iris My Choice Automatic (New) Ladies 1195.79.00</a></b></h2> crown. I like the <h3><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-double-eagle-replica-swiss-watches-4802.html">Discount Omega Double Eagle Chronograph Mens 1514.20</a></b></h3> easy to read bubble <h4><b><a href="http://www.bestswissreplicas.com/gucci-replica-watches-102-g-mini-replica-swiss-watches-6114.html">replica Gucci 102G G-Watch Steel Red Petite Ladies YA102503</a></b></h4> style font that is anything but typical for an "instrument watch," <h2><b><a href="http://www.bestwatchesreplica.com">best watch replica</a></b></h2> yet does not feel <h3><b><a href="http://www.bestwatchesreplica.com/products/breitling-bentley-quartz-chrono-breit-181-135-watch-replica.html">cheap Breitling Bentley Quartz Chrono BREIT-181-135 watch replica</a></b></h3> out of place. Inside <h4><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h4> the watch is a Swiss ETA Valjoux 7750 automatic movement that <h2><b><a href="http://www.handbagdesigner.net">lv bags</a></b></h2> has the subsidiary seconds <h3><b><a href="http://www.handbagdesigner.net">replica designer bags</a></b></h3> dial removed for a <h4><b><a href="http://www.handbagdesigner.net">cheap handbags</a></b></h4> bi-compax look. I would normally argue t
공유가 켜져있으면 하드디스크에 이름 변경이안됩니다.
OS 9라면 조절판에 파일공유에서 하시고요.
OS X로 부팅을 해서 OS 9를 클래식 모드로 사용하는 경우에는 시스템환경설정 공유에서 체크 체크를 풀어주세요.
emoticon_096 외장이름 변경은 조절판의 파일공유를 열어서고.공유를 끄고 변경을 하시면 됩니다
쿼크는 쿼크 프로그램만 실행후.. 편집메뉴의  스타일목록을 열고..정규를 선택해서 기본서체를 원하는 서체로 지정을 하고 닫으세요.
그리고.
쿼크프로그램을 다시 실행후 사용하시면 됩니다.
밤삼킨별
쿼크에서 기본세팅은
쿼크를 처음키시고 도큐는 꺼내지마시고요 -
서체같은경우는 파일 - 스타일목록 - 정규 - 편집에서 수정해주시면되고요
그외 것들은 파일 - 환경설정에서 해주시면되요
하드이름변경은 조절판의 파일공유에서  공유를 끔으로하고 변경하시면됩니다. 그리고 쿼ㄱ에서 기본 서체변경은 간접입력(파워입력)상태에서 간접입력창 맨우측에  삼각형 클릭해서 서체항목에서  원하시는 서체로 변경하시면됩니다.
