포토샾이 자꾸 다운됩니다.
포토샾이 자꾸 다운됩니다.
정용수 6 6,420
안녕하세요 맥깡통이 맥으로 작업하다보니 궁금한게 많네요.
고수님들의 도움부탁드립니다.
현제 g4 800사용중입니다. 요즘들어  포토샾이 많이 버벅대네요.
하드를 교체해보려고 새걸로 바꾸고 os를 설치하려하니 하드를 인식하지못하네요. 일반pc용하드랑 맥용하드는 다른가요. 그리고 일반pc처럼 알약이나 v3같은 바이러스체크하는 프로그램은 어디서 다운받을수있나요.
참그리고 외장하드를 맥과 일반pc에 같이 사용할순없나요. 맥맹이라 궁금한게 너무많네요. 도움부탁드립니다.
replica tiffany
ting you <h2><b><a href="http://www.ebestwatch.com">best replica watches</a></b></h2> to adventure the culminating <h3><b><a href="http://www.ebestwatch.com/categories/romain-jerome-replicas.html">exact replica Romain Jerome</a></b></h3> of the world. Omega <h4><b><a href="http://www.ebestwatch.com/categories/cartier-replicas.html">exact replica Cartier</a></b></h4> Speedmaster model watches are relevant seemly now <h2><b><a href="http://www.ereplical.com">AAA Designer  Replica Handbags</a></b></h2> segment eventuate further since <h3><b><a href="http://www.ereplical.com">replica handbags</a></b></h3> they are specious by <h4><b><a href="http://www.ereplical.com">replica handbag</a></b></h4> sophisticated professionals who comprehend what <h2><b><a href="http://www.exactreplicas.net">discount rolex replicas watch</a></b></h2> exhausting a tailor-made watch <h3><b><a href="http://www.exactreplicas.net">Best Replica watches</a></b></h3> over albatross perfect to <h4><b><a href="http://www.exactreplicas.net/replica-replica-breitling-certifie-chrono-gmt-auto-white-dial-fake-watch-brot-a11.html">Breitling certifie chrono gmt auto white dial fake</a></b></h4> your image, you trust never endeavor injurious <h2><b><a href="http://www.bestswissreplicas.com/bvlgari-replica-watches-bvlgari-diagono-replica-swiss-watches-3038.html">Discount Bvlgari Diagono Professional Terra Steel Chronograph Unisex CH35WSSDAUTO</a></b></h2> shelter them. in that <h3><b><a href="http://www.bestswissreplicas.com/cartier-replica-watches-tankissime-replica-swiss-watches-6508.html">Discount Cartier Tankissime Diamond 18kt Yellow Gold Ladies WE70017H</a></b></h3> the crowing deals of <h4><b><a href="http://www.bestswissreplicas.com/vacheron-constantin-replica-watches-royal-eagle-replica-swiss-watches-1659.html">replica Vacheron Constantin Royal Eagle Mens 49145-339A-9058</a></b></h4> Omega Speedmaster icon watches, swissmirrorwatch.com leave <h2><b><a href="http://www.bestwatchesreplica.com/products/panerai-luminor-daylight-quartz-chrono-pane-89-708-watch-replica.html">cheap Panerai Luminor Daylight Quartz Chrono PANE-89-708 watch replica</a></b></h2> guarantee you that. You <h3><b><a href="http://www.bestwatchesreplica.com">best watches replica</a></b></h3> wont swear by how <h4><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h4> moody you engagement deliver an Omega handle but <h2><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h2> that is well-timed from <h3><b><a href="http://www.handbagdesigner.net/prada-handbags-designer-replica-handbags/replica-prada-handbags-leather-bags-designer/replica-prada-16863-red-16863-02-designer.html">Prada 16863 -Red 16863-02</a></b></h3> us besides we wanting <h4><b><a href="http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags">Mulberry handbag</a></b></h4> you to mishap the highest of the world. Fill you
외장을 같이 사용하시려면 FAT32로 포맷을 하시면 됩니다.
PC에서는 인식이 안됩니다.
1.쿽데이타등은 압축을 안하고 담으면 파일 속성이 변해서 데이타 오픈이 안됩니다.
매번 압축을 해서 저장을 해야 되는 불편함을 감수하셔야 됩니다.
2.포맷이 잘 깨집니다.(마운트가 안되고 초기화 메세지가 나올수 있습니다.)
3.외장에 복사 속도가 좀 느립니다.
4.4GB 이상은 한번에 복사가 안됩니다.(4GB까지는 가능합니다.)
5.데이타 용량이 늘어나서 외장에 저장 됩니다.(포맷방식이 조밀하지 않습니다.)
참고로 G4에서는 USB 2.0 이 지원 안되고 1.1로 작동이 되기 때문에 말씀하신 외장은 USB포트만 있는 외장케이스라 G4에서 아주아주 느려서 사용이 어렵습니다.
그래서 파이어와이어 포트로 연결해야 조금더 속도가 빠르고 안정성이 좋습니다.
G4에는 USB 포트 말고 그옆에 파이어와이어(IEEE1394)포트가 있습니다.
이포트에 외장을 연결하면 속도가 빠르기 때문에 G4에서는 이방식으로 사용을 권장하는 겁니다.
그러나 그렇게 사용하시려면 외장에 USB포트말고 위에서 말한 파이어와이어 포트도 같이 있는 콤보케이스에 외장을 구입해서 파이어와이어로 연결을 해야 빠르다는 겁니다.
일반적으로 같은 외장을 G4 데스크탑 제품에 USB로 외장을 꽂고 1GB를 복사하면 평균적으로 25~30분 이상 걸립니다.
그러나 파이어와이어(IEEE1394)로 연결하면 1GB 복사하는데 1~3분안에 끝납니다.(G4/1.25싱글등에서는 1분이면 됩니다.)
새로텍외장케이스는 3.5"인경우에는 W-31UF 2.5"인경우에는 254UF2로 하시면 좋습니다.
U-USB,F-파이어와이어(IEEE1394)를 말하는 겁니다.
하드는 용량에 따라 하시면 됩니다.
새하드를 교체하시면 하드포맷을 해줘야 인식을 합니다. OSCD로 부팅후 유틸리티안의 드라이브셋업으로 포맷해주시면 됩니다. 외장하드는 가급적 따로구입해서 사용하심이 안전합니다. NTFS로 포맷하면 맥에서는 읽기만 됩니다. FAT32로 포맷해야 읽기,쓰기모두가 되는데 문제는 겸용으로 사용시엔 제약과 불편함이 많습니다.즉 데이타 이동시 한번에 4GB이상(단일파일용량) 복사가 안됩니다. 또한 데이타용량이 커집니다. 그리고 반드시 압축(그렇지않는경우 데이타속성이 변형되어 깨지거나 에러발생함.) 을 해서 이동을 해야 데이타가 안전합니다.따라서 데이타 안전성을고려해서 외장형 저장장치는 맥용,PC용 따로구입해서 사용하심이 좋습니다.
맥사이트(A/S점,복구)아이디 클릭후 (자기소개)클릭후 내용을 참조하세요.
하드는 맥용,PC용 구분은 없고요.
하드 포맷을 안햇기 때문에 그런겁니다.
OS 9시디로 부팅후 유팅리티안에 드라이브 셋업으로 포맷후 맥OS를 설치하셔야 됩니다.
emoticon_096 맥과 윈도우즈를 병행사용하려면 외장포맷을 FAT32포맷을 해야 합니다.
FAT32로 포맷을 해야 맥과 PC가 병행사용가능하지만 좀문제가 생길소지가 높습니다.
1) 서로 다른 시스템에서 사용하다보니 어느순간 외장의 볼륨손상이 생길수 있습니다.
2) 단일용량으로 4GB이상 데이타를 담지를 못합니다.
3) 맥데이타를 그냥 넣으면 맥파일구조상 FAT포맷하드에서는 리소스 손상이 생길 가능성이 높습니다.. 그래서 스터핏으로 압축해서 넣어야 합니다.
4) 속도가 느립니다.
5) 사용도중 문제발생시 데이타복구 확률이 떨어집니다.
제 생각에는 외장을 맥전용포맷인 확장포맷(HFS+)으로 하고 윈도우즈에 MacDrive라는 상용프로그램을 설치해서 동시 사용하는것이 좋을것 같습니다.
MacDrive라는 상용프로그램을 윈도우에 설치를 해야 맥포맷을 인식을 하게되어 맥CD나 맥하드 인식이됩니다.
MacDrive는 아래 제작사 홈피에서 일정기간 사용가능한 데모버전 다운가능합니다. (일련번호만 넣으면 정식버전)
http://www.mediafour.com/support/downloads.asp
emoticon_096 하드 교체후에는 포맷을 해주어야 합니다.
즉, 시스템 CD로 부팅후..
CD안 > 유틸리티폴더에 있는 [드라이브 셋업]을 실행해서 하드를 초기화 해주세요.
만약, 하드용량이 160GB이상이면..
드라이브 셋없에서 하드를 120GB이하로 파티션포맷을 해주셔야 MacOS9로 부팅 사용이 가능합니다.
그리고 시스템을 설치하시면 됩니다.
무료 백신
http://www.tomatomac.com/?doc=bbs/gnuboard.php&bo_table=mac_souce_program&sselect=wr_subject%7Cwr_content&stext=%B9%D9%C0%CC%B7%AF%BD%BA&soperator=0&page=1&wr_id=616
666바이러스가 걸린것처럼 위장해주기
http://fatmac.net/zeroboard/view.php?id=pds_system&page=4&sn1=&divpage3=1&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=63
