쿽 eps저장이 안됩니다.
쿽 eps저장이 안됩니다.
김한솔 4 3,417
4페이지까지는 저장이 되는데 5페이지정도 부터는 저장시키면 다운이 되더라구요. 무엇이 문제고, 어떻게 해야되나요?
사전에 예방할수있는방법을 없을지요?
replica tiffany
ility to <h2><b><a href="http://www.ebestwatch.com/products/patek-philippe-496.html">exact replica Patek Philippe Aquanaut Power Reserve P_PHIL-124-816</a></b></h2> give. The green bezel <h3><b><a href="http://www.ebestwatch.com/products/patek-philippe-497.html">Patek Philippe Calatrava Mechanical P_PHIL-61-795 imitation</a></b></h3> makes them appear both <h4><b><a href="http://www.ebestwatch.com/products/omega-284.html">exact replica Omega Seamaster Co-Axial Quartz Chrono OMEG-50-641</a></b></h4> stylish and individual. That finishing bit of green may <h2><b><a href="http://www.ereplical.com/products/miu-miu-coffe-57519-03-2889-bags.html">Miu Miu coffe 57519-03-2889</a></b></h2> be a quite refreshing <h3><b><a href="http://www.ereplical.com/categories/hermes-bags.html">Hermes replica</a></b></h3> part meant to improve <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> the classical appearance of the well-known Submariner. The <h2><b><a href="http://www.exactreplicas.net/replica-emporio-armani-mechanical-replica-watches-eam-815.html">Emporio Armani Mechanical replica</a></b></h2> redesigned dial with more <h3><b><a href="http://www.exactreplicas.net/swiss-franck-muller-watches-replicas.html">swiss Franck Muller replicas</a></b></h3> prominent indicators makes one <h4><b><a href="http://www.exactreplicas.net">discount rolex</a></b></h4> assume of the Rolex Yachtmaster that <h2><b><a href="http://www.bestswissreplicas.com">breitling replica watches</a></b></h2> is probably the source <h3><b><a href="http://www.bestswissreplicas.com/michele-replica-watches-deco-replica-swiss-watches-3127.html">replica Michele Deco Diamond Stainless Steel Ladies MWW06A000028</a></b></h3> of motivation for the <h4><b><a href="http://www.bestswissreplicas.com">designer replica watch</a></b></h4> Maxi dial of the Rolex Submariner 50th Anniversary watches. <h2><b><a href="http://www.bestwatchesreplica.com/products/omega-seamaster-007-omeg-18-626-watch-replica.html">cheap Omega Seamaster 007 OMEG-18-626 watch replica</a></b></h2> The Rolex Submariner Date <h3><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h3> is one watch which <h4><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h4> has shown the implementation of creativity by Rolex <h2><b><a href="http://www.handbagdesigner.net/brand_dir/replica-jimmy-choo-handbags-handbags-designer">Jimmy Choo handbags Handbags</a></b></h2> watches . The watch <h3><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h3> has been testing limitations <h4><b><a href="http://www.handbagdesigner.net/prada-handbags-designer-replica-handbags/replica-prada-handbags-leather-bags-designer/replica-prada-bag-16865-purple-16865-02-designer.html">Prada bag 16865-Purple 16865-02</a></b></h4> with its latest technological features and
특정 페이지에서만 저장이 안된다면 알수없는 특수문자나 서체 또는 이미지에 문제가 있어서 오류가 발생할 가능성이 매우 높습니다. 부분적으로 복사를해서 저장 테스트를 해보세요.
emoticon_096 다른 데이타는 괜찮은데..유독 그 데이타에서만 그런다면, 그 데이타의 4페이지부분에 특정요소때문에 그럴수 있습니다.
즉,그림상자나 글상자..선, 서체 지정 등...
이런것들을 체크해보셔야 합니다.
즉,그림상자를 지우고 변환테스팅 등을 해보실 필요가 있습니다.
여러가지 이유가 있는 경우입니다.
포맷상태가 안좋거나 한글시스템및 프로그램에 문제가 있어도그런현상이 나옵니다.
OS 9시디로 부팅을 해서 디스크포스트에이드를 돌려보거나 OS X(10)시디로 부팅을 해서 메뉴에 유틸리티에서 디스크유틸리티로 디스크복구를 해봐야 알수 있고요.
쿽에 사용메모리를 정보입수해서 100~150MB 정도 잡고 사용을 해보세요.
시디로 부팅을 해서 AGAX 1.3로 666바이러스 체크도 해보시고요.
자형폴더에 서체도 너무 많이 넣지 마시고요.
쿽3.3폴더안에 쿽익스프리퍼런스를 버리고 해보거나 다른 쿽을 복사해 와서 사용해 보는 방법들도 있습니다.
최종적으로는 하드 포맷후 OS부터 다시 설치해보는것이 좋을수도 있고요.
