pdf 변환시, 페이지, 프린터 설정에 대해..
박슬기 6 8,813
쿽3.3에서 작업후,
최종적으로 잡지사이즈 양면으로 (A3)로 출력해야하는데,
ps파일로 저장하고 pc에서 pdf파일로 열렸을땐 단면으로 나뉘어서 A4로 출력되거나 A3로 맞췄을땐 확대되서 보이거나 , 잘려서 보입니다.
ps파일로 저장할때 페이지설정이나, 프린트에서 잘못설정해 준거 같은데,
책보고 설정해줘도 잘 안맞춰지게 나오고,
뭐가 잘못됐는지 모르겠네요.
제대로 출력되는 다른 분 컴터에서 보고 똑같이 설정을 줬는데도,
pdf에서  양면 A3로 맞춰지질 안아요ㅠㅠ
replica watches
ap featuring <h2><b><a href="http://www.omegareplicawatch.net/zenith-chronomaster-xxt-open-chronograph-mens-watch-18-1260-4021-01-c505-replica.html">Zenith Chronomaster XXT Open Chronograph Mens 18.1260.4021.01.C505 outlet</a></b></h2> tone-on-tone stiching. Its small <h3><b><a href="http://www.omegareplicawatch.net">replica watches</a></b></h3> seconds displa <h4><b><a href="http://www.omegareplicawatch.net">replica watch</a></b></h4> y is <h2><b><a href="http://www.onreplicas.com/balenciaga-replica-handbags">Balenciaga replica handbags</a></b></h2> located at 7 oclock, <h3><b><a href="http://www.onreplicas.com/balenciaga-replica-handbags/giant-city/460.html">replica handbags Balenciaga "Giant City" Goatskin Bag Dark Coffee for sale</a></b></h3> and the winding crown <h4><b><a href="http://www.onreplicas.com">replica handbags</a></b></h4> remains at 4 oclock. <h2><b><a href="http://www.handbagsfake.com">fake Louis Vuitton</a></b></h2> This watch is water <h3><b><a href="http://www.enreplicas.com/replica-wallet/chanel/chanel-6-key-holder-black-300905.html">Chanel 6 Key Holder Black 300905</a></b></h3> resistant to 30 meters <h4><b><a href="http://www.handbagsfake.com">Louis Vuitton fake handbags</a></b></h4> and is a certified <h2><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-constellation-replica-swiss-watches-4709.html">cheap Omega Constellation Ladies 1365.79.00</a></b></h2> chronometer and operates at <h3><b><a href="http://www.bestswissreplicas.com/a-lange-sohne-replica-watches-datograph-replica-swiss-watches-197.html">A Lange & Sohne Datograph Perpetual Mens 410.025E</a></b></h3> a frequency of 28, <h4><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h4> 800 vibrations <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> per hour and gives <h3><b><a href="http://www.bestwatchesreplica.com/products/iwc-big-pilots-automatic-iwc-79-488-watch-replica.html">cheap IWC Big Pilots Automatic IWC-79-488 watch replica</a></b></h3> an advantage of a <h4><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h4> 65-hour power reserve. <h2><b><a href="http://www.cartierreplicawatch.net/replica-zenith-watch-cartier.html">Zenith knockoffs</a></b></h2> If unique and fashionable <h3><b><a href="http://www.cartierreplicawatch.net/panerai-luminor-1950-submersible-1000m-mens-watch-pam00243-replica-cartier.html">Panerai Luminor 1950 Submersible 1000M Mens PAM00243</a></b></h3> design is what you <h4><b><a href="http://www.cartierreplicawatch.net">Cartier Watches</a></b></h4> ar
박슬기
감사합니다. ^^
하늘아기
아하 그랬군요....emoticon_012
'A3 용지에 A4 사이즈 두 페이지를'이라는 내용을 줄여서 표현한 것인데, 그렇게 오해를 할 수도 있겠네요. 아웅~ ^^
하늘아기
엇 노훈님 실수를....으흠~emoticon_001
A4를 세로로 펼침면으로 했을때 420이 맞구요.
혹 맞춤표를 대칭으로 설정하신건 아니신지요? 그러면 맞춤표가 나오기 때문에 오른쪽과 아래쪽이 잘리게 됩니다. 맞춤표를 나오게 하시려면 20mm이상 더해서 설정을 해주시면 됩니다.
그리고 프린터 기종이 일반컬러, 혹은 일반 흑백으로 되어 있다면 용지폭 설정이 아예 안됩니다.
쿽에서 ps로 저장하셨다니 그럴일은 없을것인데 혹 용지에 맞게끔 혹대 또는 축소가 설정이 되어있다면 확대 되거나 잘릴수 있습니다
QuarkXPress에서 파일 > 페이지 설정으로 들어가면 페이지의 폭을 입력하는 항목이 있습니다.
여기에서 정확한 칫수를 입력하셨는지요?
예를 들어, A3를 세로 방향으로 해서 펼침면으로 출력을 하는 경우에는 420mm를 입력합니다.
PDF 생성 시에는 이 내용이 무척 중요한 설정이니, 이 부분을 먼저 확인해 보시기 바랍니다.
