포토샵저장관련에 오류
포토샵저장관련에 오류
은미 5 9,528
포토샵 작업중 저장시킬려고 하니까 계속 이런문구가 뜨는데
메모리가 부족하다는것같은데 왜그런건지요ㅠㅠ
혹시아시나요?
Could not complete your request
 because there is not enough memory (RAM)
replica tiffany
ra? 90 <h2><b><a href="http://www.ebestwatch.com/products/bvlgari-773.html">exact replica Bvlgari B.zero1 35mm BVLG-55-234</a></b></h2> from 43 balls. Sehwag <h3><b><a href="http://www.ebestwatch.com/products/breitling-74.html">Breitling Navitimer Quartz Chrono BREIT-219-205 imitation</a></b></h3> had the record individual <h4><b><a href="http://www.ebestwatch.com/products/patek-philippe-497.html">Patek Philippe Calatrava Mechanical P_PHIL-61-795 imitation</a></b></h4> score in his sights, but soon after the batting Powerplay <h2><b><a href="http://www.ereplical.com">replica handbags</a></b></h2> was taken, Welegedara returned <h3><b><a href="http://www.ereplical.com/categories/chloe-bags.html">Chloe replica</a></b></h3> to get him with <h4><b><a href="http://www.ereplical.com/products/miu-miu-with-shoulder-strap-in-peachblow-57511-2779-bags.html">Miu Miu with shoulder strap in peachblow-57511-2779</a></b></h4> a low full toss that lobbed to point off the <h2><b><a href="http://www.exactreplicas.net">best exact replica</a></b></h2> leading edge. Dhoni, after <h3><b><a href="http://www.exactreplicas.net">replica watches</a></b></h3> 72 from just 53 <h4><b><a href="http://www.exactreplicas.net/replica-panerai-luminor-marina-replica-watch-pani-809.html">Panerai Luminor Marina replica</a></b></h4> balls, followed four balls later, miscuing a slower ball from <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> Fernando into the hands <h3><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-constellation-replica-swiss-watches-4595.html">Discount Omega Constellation Quartz Mini Ladies 1158.75.00</a></b></h3> of cover. The stutter <h4><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-de-ville-replica-swiss-watches-4842.html">Omega De-Ville Co-Axial Chronograph Ladies 4673.60.37</a></b></h4> continued as Gautam Gambhir edged Kulasekara behind, <h2><b><a href="http://www.bestwatchesreplica.com/products/blancpain-dual-time-tourbillon-bp-9-32-watch-replica.html">cheap Blancpain Dual Time Tourbillon BP-9-32 watch replica</a></b></h2> and the Powerplay fetched <h3><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h3> Sri Lanka three wickets <h4><b><a href="http://www.bestwatchesreplica.com/products/ferrari-chronograph-ferr-3-419-watch-replica.html">cheap Ferrari Chronograph FERR-3-419 watch replica</a></b></h4> for 33 runs. Raina and Harbhajan didn? inflict much <h2><b><a href="http://www.handbagdesigner.net/louis-vuitton-handbags-designer-replica-handbags/replica-louis-vuitton-handbags-lv-handbags-2008-designer/replica-m93583-designer.html">M93583</a></b></h2> damage, but attractive cameos <h3><b><a href="http://www.handbagdesigner.net">cheap handbags</a></b></h3> from Kohli and Jadeja <h4><b><a href="http://www.handbagdesigner.net/balenciaga-handbags-designer-replica-handbags">Balenciaga</a></b></h4> ensured that the last few overs would
박인옥
저는이미지 따다 쓰는 과정에서 ibm은 열리는데 맥에서 안열려서
고생했는데 ibm에서 새파일 열어서 다 끌어다가 다시 저장하고 맥으로 데꼬 갔더니..열리네요..히유...
<내장 메모리대한 정보>
쿽3.3은 100MB이상
일러스트9는 150MB이상
포토샵6은 250MB이상
내장메모리에 여유가 많다면 더 많이 잡아주시고요.
대도록 포토샵에 많이 할당을 해주세요.
가상메모리는 끄세요.
G4라면 1GB이상을 권장합니다.(내장메모리)
보통 2가지 입니다.
포토샵에 사용메모리가 너무 적게 잡혀있어서 그런경우와 파일자체가 깨진경우 입니다.
일단 포토샵 실행 아이콘을 정보입수(커맨드+i)를 해서 사용메모리를 300MB(300,000)이상 잡아주세요.
물론 내장메모리가 높다면 더 잡아주시는것이 좋고요.
내장메모리가 1.5gb라면 대략 600~700MB정도 잡아주면 좋습니다.
포토샵 응용프로그램 정보입수에서 메모리에서 사용메모리를200000~250000정도 설정후 실행해보세요.그리고 한글시스템안의 프리퍼런스폴더에서 포토샵관련 프리퍼런스폴더 삭제후 사용하세요.
